Enable PTP end-to-end-transparent clock functionality (1-step PHY timestamp) on the ports.
| port_list | List of physical ports. |
N/A.
See Description.
The following example enables end-to-end transparent clock on the front panel ports 1-3:
enable network-clock ptp end-to-end-transparent ports 1-3
This command was first available in ExtremeXOS 15.1.
This command is available on 5420, 5520, and 5720 platforms.
